Those are grinder marks from the OEM casting where they did casting flash removal prior to machining. That's why those marks don't affect the inner axle seal seat opening.
Nothing to worry about.
Some of the folks posting in here will show marks inside the housing that are a result of a Birfield exploding and the balls and chunks rolling around in there or loose wheel bearings and the Birfield would grind inside the housing. They difference is that those usually end up chewing up the upper trunnion bearing area.
Make sure your axle guide washer is still intact behind the inner axle seal. This guides your axle shaft to reduce damage to the seal during assembly and in case the Birfield or wheel bearings are loose.
i noticed those marks on mine last weekend when fixing a leaky seal.
the Birf looked fine so assumed it was a manufacturing thing as its never made any unusual sounds
