I recently purchased a 2013 GX460 and it appears to have what I assume are cats attached to each exhaust manifold, and downstream are two more on each bank. Are some cats while the others are resonators?
What headers did you go with?The OEM Toyota cats are very high-quality and high-flow. However, as indicated above, the two cats in the Y-pipe are downstream of the O2 sensors. Removing them will not trigger any O2 sensor codes but may cause issues with visual or tailpipe emissions inspections if you have those in your area. If not, it should be no big deal. Also, your downstream cats may be worth $400-700 in salvage value.
The Brockett Y-pipe does look pretty awesome and is reasonably priced. I may consider the catted version for my GX470, which selling my old cats would cover half of. However on a GX460, I am not sure you would get much of a performance gain due to the very restrictive OEM exhaust manifolds. I have headers on my 470, so other downstream exhaust upgrades have resulted in extra power.
Did the Careless Y-Pipe eliminate the 2nd set of cats, or keep them? Did you scan for codes after the CEL?I installed a careless y pipe and got a CEL. Insane drone too. That thing was off after only a week.
It did… sorry, post should’ve said “cat-less”. Scanned codes and it was O2 sensor lean… forgot which bank though. Didn’t really matter… the highway drone was enough to make me promptly take it back off. Broke one of the studs off the drivers side cat taking it off… not a fun weekend.Did the Careless Y-Pipe eliminate the 2nd set of cats, or keep them? Did you scan for codes after the CEL?
Didn't recieve it without picture proof!!Well gents, my Brockett Built resonated Y-pipe arrived today! Before and after sound clips coming soon. Planning to record sound from drivers seat at start up and run, as well near front right tire and rear right tire.
