I replaced mine a couple of weeks ago. Keep in mind that the one manifold gasket may not be the only one you will need. On my 86 4runner, there are also two gaskets for the air inlet tubes. In my trucks case, the holes are plugged with plates and two gaskets. they are around 4"x 1". I ended up having to buy a exhaust gasket kit to get them.
Then there are two round flange gaskets at the manifold to the pipe. You'll want to remove the manifold to clean it and check it for warpage if you have the straight edge, so they'll come off and should be replaced as well.
And if you're going through all this trouble, consider replacing the pipe to cat flange gasket. that may be a part of the leak.
Have fun.
And to think I complain about having to work out under a tree when it's 70 degrees out. Gotta love socal weather.
