Hi, I just installed a refurbished internally regulated OEM alternator on my 1984 FJ60. To my dismay, this rather expensive part isn't working. Battery charge is approx. 12v when motor is off and 11.5 when motor is running. Another curious symptom: When I unplug the alternator after killing the engine, my carburetor fan begins to run, as it normally did prior to replacing the alternator. (I have it wired to always run after shut-off, no temp switch.)
I did a bit of research that got me wondering if this alternator needs to be excited or re-excited initially before it will start to produce electricity. Does anyone know if that might be the case, and if so, how do I do this?
Thanks for your prompt help... This is my daily driver, and I'm a bit stranded if I can't get it working!
