Some Additional Questions
Hi all, well I went and picked up the compression tester from sears that brent and some others recommended. Thanks again fellas for the recommendations. The kit looks like good gear; nice hoses, lots of adaptors, nice gauge. Of course the kit is no where near as nice as the Snap On ones I'm sure, but, I'm a weekend warrior and not a pro like Robbie, Gumby and some of the others here so I figured 50 bucks vs. 225 bucks was better at least for me.
I hope to test the compression this weekend when i'm scheduled to swap the plugs and in preparation for that i read the instructions to the tester. One thing in particular was perplexing ... there was a long warning written about NOT using the ignition switch on fuel injected vehicles and that a remote start switch should always be used with any fuel injected vehicle. The explanation was that some but not all late model vehicles trigger the fuel injectors when the ignition switch starts to crank the engine. The warning was worded in a way that made me think this feature cannot be cancelled in these vehicles although I think in essence many here have found a way to do that to their rigs. Is this why some here recommend removing the efi fuse or the efi relay? What really is the right way to disable the fuel injectors cause I'm sure almost everyone IS using the ignition switch, right? There was a thread that pretty clearly spelled it out but when i just searched for some reason i could not find that thread???
The other question, and something that I think was also answered in that other thread was, what is really the right way to disconnect the coil? Should you simply remove the lead from coil to distributor? Should you remove the small two wire connector that goes to the coil and then just let that hang at a distance? Should you do both? I seem to remember something about one way that works but potentially stresses the coil pretty hard, I'd like to avoid that way.
The last question, I promise, is several here suggested that by the time that you get to the last cylinder alot of times the battery is worn down somewhat from all the cranking. Would hooking up a trickle charger while testing the compression by advisable? Or, would hooking it up in the middle of the test and letting it charge while enjoying a #6 be part of this procedure? I cant imagine the batt getting that low that fast but if I should charge it in the middle or throughout the test, then that is easily done as well.
I'd appreciate any advice at all about any of this. I know much of it was covered but again I cannot seem to come up with it, and at least in my memory there was some conflicting opinion, imagine that! Thanks again all, and thanks especially to brent for traking down that part number for me.
