Still working out the kinks on my 05 LX. The inside would smell of mold everytime I would get in. I also noticed a drip on the passenger side carpet after running the AC and did a quick search on here. Turns out I needed a new evaporator box seal. So ordered one for $11 and just finished installing it.
Heres how I did it and it seems to have cured the leak and the smell.
1. Take out the glove box to get to this:
2. Take out the cabin air filters and unscrew the antenna relay with the 2 large screws in the above picture and undo the connector
3. Take out the 8 or so screws on the evaporator box cover to get to this:
4. There is a small connector clip on the top left of the evaporator cover attached to a cable. You will need to undo this too
5. You will need to pry the evaporator box cover off now and work it loose so it comes off and out from below. Use your hand to pull on the horizontal bar where the glove box screws go and gently to work it out downwards to get to this:
6. Now clean out the leaves and other crap from the right side of the evaporator and you will smell that familiar smell and know you are at the right spot
7. Take out the old seal from the bottom of the evaporator housing here:
8. Insert the new seal like so:
I can only attach 5 pictures at a time here so will post the rest in the next one....
