(ET) Extra Thread Lug Nuts needed
Raleigh, NC
I don't want to add a bolt on spacer and create potentially issues but I want to a spacer between the hub and wheel to change offset by 10mm (+50MM is recommended for 33" wheel size). With a spacer, definitely I will not have enough thread left to have the required 8 rotations.
Did anyone buy and can recommend extra thread (ET) lug nuts that will work on 16+ LC. In the attached example the lug nut has an extra neck to engage thread earlier which is the type I am looking for. I am open to both black or chrome finish lug nuts. Thx
1920916
What wheel are you going to use these on? What is the required mating surface?
you will need to change the studs to do that.. not the lugs. you would need M14x2" studs.
OEM is M14 x 1.5" ... i just got some match the trailer to the vehicle. so 10mm is just under 1.2 which is about 1/2 ".
Now you can get stubs that are m14x1.5" and seat differently. i.e. stick out further and that's another option for what you want to do.
Thanks! Looks like 2" is way to go. Thanks for all the help!
lots of folks running spidertrax spacers, I cant recall anyone having issues. Just saying....
That was my first idea. Unfortunately I cannot go that wide. I have moved to 33" size and will deal with rubbing at lock and definitely don't want to cut fender covers or mud flaps. Trying to see how much wider stance can go without cutting into fenders, etc. Could go smaller tire, but prefer the bigger tire look on 20" wheel than wider stance.
