I have a 62 with a 12v 2H. The 2H came from Canada and the 62 body is American. Torfab did the conversion years ago. Because it's a 12v, the starter and alternator are not original to the engine, but I couldn't tell you where they come from.
The issue I'm having quite frequently now but over the years only happened once every couple months is the following: I turn the key and hear a click but the starter won't engage.
I have replaced my batteries (Interstate Megatrons wired in parallel), I have tried replacing all my battery cables and ground straps (in the engine bay, at least), and no difference. Recently, I even installed a remote starter button that's wired directly to the battery and to the starter solenoid. When the key won't work, there are some times that the remote button works. Other times, neither works.
I've had luck banging on the starter, but then it's gotten to where that doesn't work all the time. I've tried jumping, but that's not consistent, either.
Voltage at my batteries reads 12.6+. I get good voltage at the post on the starter, even at the terminal on the solenoid. I've taken the starter to a shop and he says it tests fine.
I can't figure out a common variable so I'm having a hard time diagnosing it.
One thing, there is no starter relay. The column ignition goes straight to the solenoid terminal.
Thanks,
Ara
Thanks,
Ara
