I think with all of the blown 1FZs due to HG failure a used crank would be a pretty easy thing to find.
I posted in Classified, we'll see what comes up. It sounds like I'll need an engine jack and pull it all out to get at it then huh? Arg... I was just getting to know her too...
You will pull the block if you are going to repair that engine ... the slippery slope is that once the block is out ... you may as well consider rings, valves, pistons? rods? wrist pins? timing chain maybe gears etc etc ... yadayada.
Labour time and parts cost (and the inevitable shortage of SST tools/gauges) it maybe better to look at a factory short block which has been assembled in appropriate environment with tools/gauges that are appropriate to the application OR a lower mileage long block from a salvage yard.
Oh, and BTW, I am glad you are swapping in a motor built by the Japanese guys at the factory.
Would this work for this application?
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Will I need anything special for the tranny? I figured I could just use my regular jack on it, but do I need to get an adapter or anything? I think I have a skateboard lying around, will that really work? I'm not quite following all your ups and downs. But I guess I'll figure that out when I get there.
The poor guy way of doing this is...
Lucky I am still alive, but it does work.
I think he was referring to a post above of a new short block being the best solution. I don't think(hope) he was being racist. The real irony would be if SBFJ is Japanese, or is the irony that I'm Chinese and don't trust my own rebuilding prowess? Either way SBFJ, as previously mentioned, you have full rights to work on my 80 anytime you want. I'll have it sitting in my shed with a tarp over it with your name on it.
maybe he means a Xtra HD furniture dolly... don't think I have seen a skateboard that would take the weight of the "80's block - and balancing it would be a pretty good feat.place old carpet or skateboard under the motor
Yes - I understood where you were going on that Snowtire .. I have seen VW/Porsche/Renault Dauphines a BMW Isetta and one NSU done this way .. eg engine dropped on a dolly .. body lifted and engine dragged out from UNDER the chassis. But the challenge with this on an '80 might be daunting ... as mentioned earlier .. there is a very large axle in way among a lot of other issues...... it would be very handy if it could be accomplished this way though!!: the lack of clarity in my engine swap procedure. Sorry. In this procedure, you lower the engine onto a skateboard or a piece of carpet and then slide it out from under the car. Probably not the best idea with a massive hunk like the ones in our trucks. But it works great with flat fours and sixes in German cars.
