Hsiaoer's thread about rod bearings is making me want to pull my motor and clean up all the leaks. However if I'm going to do that I might as well replace the short block.
What is everyone's opinion? I have a motor with 206k on it, makes a tapping sound while running, and the rear main leaks. Oh, it burns/leaks (mostly burns I fear) about a quart every thousand.
Should I pull it and reseal it or do I pull and replace with a new OEM short block? The reseal would be a few hundred bucks by the time I do OEM hoses and gaskets. Somewhere around $3k for a new short block on top those other things.
By the way, I'm the type that spends $700+ to completely refurbish the sun roof with new rails/seals. So I’m particularly susceptible to while-I’m-in-here-itis.
