Engine Swap Info Needed
Alabama
Can anyone on here confirm that a 1985 2F engine block, head, valves, etc. would be a direct swap into a 1983 FJ60? Meaning would the carb, pulleys, transmission, vacuum lines etc all be directly installed? I have an 83 model that is in pretty good shape but it has a bad cylinder. I also have an 85 model that is in rough shape but the block and head etc are good so I am hoping I can swap them out and just replace seals and gaskets etc. Thanks for any info!
Yes, no issues, direct swap, no changes between 1983 and 1985
  • Like
Reactions: OSS
If you’re just swapping the block & head, it’s a direct swap
