I have a 1975 Fj40. The engine is stock. Recently it has been getting harder and harder to start it up. I really would have to hold the key in the start position forever and pump the gas pedal to get it started. More just hold the the key in start position to get it to fire up.
Also sometimes when I shut it down it sounds like it wants to fire back up right before the engine finally dies. It does not backfire.
However today I went on a long drive and I could hear the exhaust sputtering every now and then on acceleration. After about 1 hour it got really bad. When in 1st or 2nd it sputters so bad it's like the engine might die. If I run in 3rd gear at high RPM's as in right before to move it in 4th the engine runs fine. Once I put it into 4th it starts sputtering really bad again and can't accelerate. After maybe 8-12 minutes of flooring the gas peddle in 4th gear and having in sputter not gaining any speed it seems to finally pick up acceleration and eventually I'm running at about 65-70 mph (34' tires, 4.11) and sounds are runs great.
Any ideas whats going on or where to look. Ignition issue or carb issue?
