- Joined
- Apr 19, 2013
- Threads
- 5
- Messages
- 45
- Location
- wear civilization fears to tread
- Website
- www.jaredlloydphoto.com
Hey folks I'm having som trouble with my 2000 stock LC.
I filled up my tank the other day and with a de minutes started to notice a slight vibration when I came to a stop. This progressed over the next couple days to a much rougher and noticeable shake when I was coming to a stop. My first thought was a vacuum problem.
Then the shake started happening when I was giving it gas, accelerating, and at hwy speeds. I noticed that the rpm would drop about 500 before it happened.
After an hour of driving the other day, the problem began to occur at 60mph. The shake was the worse it has been. The check engine light starts flashing indicating a misfire.
The misfire has not occurred since.
Now, when this occurs I also have a big loss of power and performance. Normally the truck is very quick and responsive. Now it becomes sluggish when this begins.
When I realized this started after filling up I started to assume bad gas. However I ran the tank to half with a bottle of Lucas in it and refilled elsewhere with premium and have now ran through half of this tank as well and problem continues.
I'm 2,500 miles from home on a road trip and desperately trying to figure this out as there is now way ill be able to make it back across the country like this.
Thanks so much in advance!
