You're correct. When that was happening, the vehicle had just restarted with no more input. However, I'm beginning to think there is another gremlin. Lately, while just idling in the driveway the engine can/will sometimes just stop. No stumbling, no noise, just nothing. (Not even a last gasp). I've been able to just walk over and restart it with no problems. Last night, the engine quit about 3/4 of a mile from the house. I ended up having it towed home. Friends stopped and tried jump starting it to no avail. The engine would turn over with no issues but would not start. After having a jumper cable connected for @ 15 minutes, the truck would crank fast but no luck. Disconnect the cables and the battery is dead. Hmmm. Once it was home, I plugged in a large battery charger with 200amp start feature. On the second try, it started right up and idled normally as if nothing had happened. I'm replacing the battery today, but I don't think that's the complete culprit. I'm rechecking the fuses, wiring, etc... to see if there is anything else amiss. I'm also going to replace the fuel filter and may replace the fuel pump as well.
