I am leaning toward the plastic version because it can easily do double duty on my boat. In a ski boat that is wet all the time a metal-cased cooler is not the best solution.
Funny you mention this.CONS:
3) Noise/vibration is on the high side. I sleep in the truck and started turning it off at night as it would wake me up when it cycled. Also people will hear it outside of the cruiser with the windows all closed and sealed up. It sort of resonates inside the plywood inclosure I have it in. That might be part of the problem as well and making it louder yet.
CONS:
1) My Arb version has nothing that keeps the lid from falling off the hinges. I have no idea why they did that but it's pretty lame. Lots of fun at night when someone gets into the fridges and come out with the lid in there hand.
I researched this a short while ago, thinking I was just going to buy the Engel, but I actually ended up getting a Waeco instead, a choice I’m very happy about.
I’ll try to summarise why:
The main reason to avoid the Engel is that they use the Sawafuji swing compressor and not the Danfoss BDF series compressor and controller (used by most others).
- A Choice test showed that the Engel is much slower to lower the temperature (131 min vs. 60 min for a Danfoss powered fridge) while average current was 10% higher.
- In a South African test in very hot weather (43 degrees Celcius) the Engel had to work continously and only reaches +3 degrees Celcius whereas Danfoss powered units were still cycling on and off yet they achieved minus 12 degrees Celcius and better.
- In the Choice test this was -6 for the Engel vs. -10 for a Danfoss powered unit.
- Engels own test data show that the Sawafuji compressor is only just able to reach freezing when the ambient temperature reaches 45 degrees Celcius. At this ambient temperature a Danfoss can reach minus 10 degrees Celcius.
- The Danfoss is significantly quieter and almost free of vibration as opposed to the Sawafuji vibrating unit.
- Supposedly, the newer Engels have had problems with their electronic components and it is very expensive to get an Engel repaired.
The reasons for selecting the Waeco was that I found that the Waeco’s have:
In case you want more details, I got a lot of the information from this web site: Ray's Caravans, Campervans & Motorhomes - Portable Fridges 1-
- best control panels
- three position low voltage battery cut-out
- display of error codes
- light weight
- good insulation
- both AC 110-240 and DC 12-24 operation
- good slides, 3 different mounting systems
- cover available for further insulation and protection
- turbo cooler setting
- detachable lid
- detachable carry handles
- built-in light
- good warranty
- less expensive.
Yesterweek I was camped up at Mt. Rainier in my roof top tent.
With my head on the pillow I could hear the cycling of my fridge inside of my rig.
The fridge is behind the drivers seat.
The noise traveled from inside of the rig to the roofrack, then transmitted from the tent base to my pillow.
As a side note, the Engel rep at the recent Outdoor Retailer show informed me that the new plastic Engel uses slightly more power than the 45. Might be of some use to know if you like to spend a considerable amount of time in one spot without running your vehicle.
