- Thread starter
- #21
Installation Commentary
It seems my comments appear to "complain" a lot. That is my nature plus I have been doing this work with a broken ankle (boot to come off next Wednesday, 3/27). So I'm a little more whiny than normal.
System went on pretty good for being exhaust work until I got to the tailpipe where the mounting point wasn't obvious.
Tail pipe Bolt: Now I have to find a bolt to go into the factory threaded hole for the tailpipe mount. Where do you get bolts for this circumstance? I plan on getting out my tap set to figure out the dia & threading, but then where do I go to find that bolt?
I'm not too concerned about fitment once I get back on it now that I know where it is supposed to go. I'll loosen up everything, pry and twist, and figure it out.
Video? I don't think you need it. If you want more pics, I'll add ALL mounting points and pipe clamps later.
Back to Mixelplix:
Donuts - My kit came with them.
"Bolts from the factory" - I'm confused. Did you take off the factory exhaust hanger brackets? I left mine on and simply broke off the little factory bolts through rubber. The only bracket I removed was the one behind the PS rear tire for the tailpipe (the 4 bolts were in great shape).
Cut body mount - can you add a pic so the folks have "my way" and the "right way"?
Gas tank strap - Did you have to remove the entire strap to get it to work as I described?
Back to Mixelplix:
