Emergency brake install...
imyahucklbrry
“In Vino Veritas”
GA - As close to the lake as I can afford...
Other than the cable assembly itself, what other parts should I source to reinstall the parking brake?
*PO had informed me that the cable got snagged on a stump and snapped... I’m guessing he removed everything and tossed it like so many other items I’m still discovering four years later!
Thanks ahead...
1982 FJ40
This might help , its technically a 60 set up but should be very similar
Any of the cotter pins , hair pins , and 46420 Dowel Pins Is a start . At Both Bell Cranks at each wheel
Also , 46304b the bushing at the equalizer is a wearable moving parts topic
Thanks...... hopefully these odds/ends are still obtainable :rolleyes:
wait, wasn't the FJ40, even in '82, still a transfer case parking brake?
The Rear axle cable system was introduced along with the split transfer-case / No parking brake drum in 8/80-
46410-60130
  • Cable, Parking Brake
  • 8/80-10/82 Toyota Land Cruiser FJ40, BJ40, BJ42 (LHD) Left Hand Drive
  • OEM Reference: 46410-60130
ON USA TRUCKS; some global market 40 series continued to have the e-brake system on the split-case until the introduction of the 70 series. :meh:
Based on his Back-lit knob / Rheostat dimmer equipped headlight switch @imyahucklbrry has a USA Spec. truck
The NON-USA 8/80- Later parking brake drum set up is interesting
My rear axle: I see where the cables should go...
And true to my MO.... nearly 2 years later, I’ve gotten around to a planned project! Nice to have a functioning e-brake and ditch the chocks ;)
