Electronic Chirp with no crank no start
florida
The landcruiser has been sending me some weird quirks the last week. Started by turning off on me twice on the way to work 20-30mph I would pull over and it would start right back up.
Later that day leaving work after checking fuses, alternator/battery voltage cleaned terminals. I got to start and get a no crank no start. After about 10 mins of seemingly doing nothing it cranks right up and drives home fine. Same this morning go to leave no crank no start. Remove the starter relay and plug it back in 2 more no crank no starts then it fires right up.
Both times it did this it’s sending some electronic chirp under the dash. Does it randomly for about 10-15 minutes then stops. Luckily was able to catch a video of it.
I have not heard the chirp, however I have had similar instances. I won’t lie, I bought a new starter relay and never installed it due to the issue suddenly stopping. Every time I had a no crank/no start issue though, putting the truck in neutral always got it to start. Maybe try that next time it happens? Sorry, I have nothing else for you unfortunately, hopefully yours magically stops like mine did.
