Electric To Mechanical Hub Conversion
yotahed
Diesel Head
Kelowna, B.C.
First off, I dont mean to tread on OldBlue's parade. This was his idea in the first place.
But for those of you who want to tackle something yourself, this is my second method of converting to manual hubs while retaining all stock parts beside the electric motors. and doesnt require machining a fake motor.
My first version used a metal ring in between the outer cover and the body, the same shape as the outer hub cover gasket as a retainer to keep the bolt straight. It tended to let a lot of moisture in so I scrapped it after a year or so, and Im using a slightly different method this time with larger hardware (5mm instead of a dinky 4mm).
The 5mm allen head bolt should be long enough to reach through the outside of the hub cover to just past where the motor was +5 or 6mm. (See picture.)
You also have to carefully grind the bolt on two sides so the the gear just slides on to it. be careful not to grind the bolt off center creating a cam-like or eccentric rotation.
using 5mm bolts requires filing the rounded edges of the square hole in the gear (once the motor is removed and the gear removed from the motor). I used a chainsaw file slightly ground on two sides to fit through the hole. Takes about 10 mins per gear. if you want to use 4mm you can, and you dont have to file the gear. Theyre pretty tiny though...
I used rubber grommet things from the nuts and bolts section in canadian tire. some stores dont have them but some do. These are the smallest they have I think (see Pic) There is a threaded insert at one end that i just cut off with a utility knife right at the edge of the insert.
Now the DO OR DIE part. Drilling your cover plate. What i did was lay the hub cover on its face on a table. take a pencil with a sharp end and put the gear on it snugly. make sure the end of the lead sticks through. put the gear up to the driven gear in the hub cover so that the gears are meshed and make sure the pencil is dead straight. you will want to take your time here, because you have to be really accurate or your bolt wont be straight and the gears wont mesh enough or will be too tight. Mark the location on the inside of the hub cover. should be right in the center of the indented area where the motor stuck out. You can alternatively use a small awl and smack it to mark the aluminium.
Measure your grommet and make the hole just slightly smaller for a snug fit. start with a small drill bit to ensure you dont walk around the center.
My hole is just over a 1/4" and the grommet fits snug. take your time here because too loose and youll have rusty hub innards before long...
Now insert the grommet into the hole and insert the bolt with a washer on it. put a washer and a nylock on at this point. the washer outside diameter should be larger than the grommet and the hole you drilled. the grommet should be just long enough to squish a bit when you tighten it. some trimming may be needed. make it real snug, but not over-tight. enough that you can still turn the bolt but without it rattling around.
Slide the gear onto the bolt and it should line up perfect if youve done it correctly.
After you get it lined up put a washer over the gear and install a nylock the normal way and snug it up tight so the gear doesnt wobble. Make sure while you are tightening you dont disturb where you set it at i.e. secure the Allen head so it doesnt move.
Now, youll need to fabricate a plate where the motor used to sit. I making mine out of 24gauge sheet steel. Have a look at the motor and diagram and youll have a pretty good idea of the shape it needs to be. Its easier to mark your holes and drill before you cut it out. Im just using tin snips. depending on how far your last nylock protrudes from the inside face of the cover plate, you may need to bend the middle in a bit for clearance.
Once you get this far, youll need to make sure youre hubs in either locked or unlocked and all the pawls are aligned. this is kind of tricky since its easy to confused. once you get the sweet spot the cover should slide right in fairly easy. jacking the wheels off the ground makes it easier so you can rotate the tires. I moved them to the lock position myself. then rotate the allen head COUNTER CLOCKWISE to position the driven gear to"lock". It will go 2 1/2 turns till it stops lock to unlock. If you dont do this you wont have full rotation one way or the other and it wont work. So make sure you pick a position and make sure the driven gear is at one of the stop postions.
CLOCKWISE to UNLOCK
COUNTER CLOCKWISE to LOCK
once you get it all together, tighten it down snug, and rotate the Allen head. you should hear the hub click in and the gears meshing and out with a couple rotations each way. if you cant, or it's not engaging, it's aligned incorrectly and you have to pull the cover and rotate the driven gear all the way to one side or the other or the pawls are in the wrong orientation. Lots of trial and error at this part. take your time.
Now you have manual hubs. Ill take some more pics tommorow while im installing mine.
:beer::beer:
anyone let me know if i missed something, I had to peee :flipoff2:
Motor plate
Here's some pictures.
I omitted three of the nuts because they are thicker than i expected. you should only need two if using 5mm hardware (see edited diagram)
some more pics. Havent made the retainer plate yet, will post up final pic possibly later on today
Cover plates are installed this morning and working perfectly. Even without the Plate where the motor used to be, they function flawlessly. The 5mm nuts and bolts made a large difference in how sturdy the assembly is on it's own.
Took me about an hour to do both sides and be driving. But I already had the holes drilled and had practice installing and removing. :D I havent made up the plates yet, but I will eventually, for now I'll run em.
Cheers
Thanks Redd.
I know the bolt head protrudes out a few mm, so a guy will have to watch rubbing the hubs on rocks and trees and stuff.
I might still go with Radd's adapter spacers, when the wallet allows. these will do for the winter.
One thing to note
Dont use any kind of sticky or tacky grease in the hubs. Makes them sticky and harder to engage (go figure) ask me how i know lol.
A good slippy lithium or something similar would be advised. Somebody else would know the correct name for it. Oil would probably work.
So ignore the Red Tack in my outer covers in the pictures. I wiped it off soon after completion.
:whoops:
Nice work yotahed! That is a pretty stealth setup. If anyone ever stole your vehicle they'd never figure out how to get the 4wd working lol!
I'm in the middle of a full swivel hub rebuild right now, and 3 out of the 4 e-hub brushes are completely missing from my hubs. I've been contemplating going to manual hubs, but cost was a factor. Your method is nearly free, and I may just go this route. Thanks!
I have a set of adapter plates and a full set of spindles, and e locking hubs I want to get rid of.
Completely open to offers....
Hubs still working flawlessly after the freeze thaw freeze, smooth as butter. and came in mighty handy with all this white stuff around.
GTS- shoot me a PM with you phone digits and I can walk you through it in more detail if you like. The hardest part is drilling the hole really. The first time i took my E hubs apart (when I actually learned what to look for that is.) The brushes were non existant as well. Had them working for a short while then intermittently. Then I got p!ssed off and did my first conversion.
this 2nd method works much smoother and is way tighter.
cheers
Hub conversion Kits
If anyone is interested, I've had a few people ask if I can put a parts kit together with the nuts, bolts washers and grommets.
Ill charge 10$ for the parts and my time CDN + shipping.
It will include:
3x 5mm allen head bolts(in case you screw one up)
2x rubber grommets
4x 5mm Nylock nuts
6x 5mm Washers
Written Instructions on how to complete the job with reference to this thread.
Im going to go grab a few kits worth of parts tommorow,
I can also make up a few fake motor plates for those who are non-metal-working-inclined. :D although they arent completely necessary if you use a gentle hand and some common sense.
PM me if interested.
You will need your own motor gears, grinder, small chainsaw file, small metric deep socket, allen key and drill bit to complete the job. My technical support is free, so dont hesistate to ask questions
:cheers:
I should note that the screws that secure the motors are very tiny and quite hard to get out. If you end up having to drill the heads off(as I had to) A tap and die set for a common small screw size is your best friend. Drill the rest of the screw out CAREFULLY and re thread it. Maybe I will add 4 small allen heads for this purpose and will include size and thread pitch in the documentation.
4 Hardware Kits Ready
I have 3 Hardware kits ready to go. The 4th is spoken for.
2 Kits Left. Will re-supply if interest continues.
cheers
Looks like a great simple fix! Yotahed... sorry for resurrecting this conversation.. After a couple of years using it- how has it lasted? Still working well? Do you still put together the kits? If so, let me know- I think I will be interested in one. Thanks!
