Hello all,
I have an electric switch mounted on my '40 to help keep the SBC cool. I have an aluminum radiator with a probe that is mounted through the radiator to turn the fan on and off. I also have a manual "on" switch in the cab. I've noticed that my temperature gauge seems to rise above the 195 degrees without the fan turning on. I've tried to move the probe to various locations on the radiator (closer to the water inlet) but I'm still not having any luck with the fan starting without me manually turning on the switch. My question is, if I change to a threaded switch, where is the best location for it? I've considered installing it in the thermostat housing, but then it will only turn on when the thermostat is open and not necessarily when the water temp of the radiator is above the 165 degree set point. I would ideally like to have the fan turn on when the water temp in the radiator is above 165. Once the return hose is empty, the sensor likely wouldn't be reading anything. Am i thinking about this correctly?
Thanks,
zglad
Thanks,
zglad
