Hi All-
Got another question for you.
For a few months, since the stalling, bucking surging debacle, I have had the EGR modulator hose at port Q disconnected from the top port of the EGR valve and plugged with a screw. The truck has been running fine ever since. I just got a new EGR modulator and tried to reconnect that vacuum line but the truck is still bucking, hesitating and surging at around 1500 rpms as soon as I do this. When I disconnect the hose and replug with a screw, the truck is back to normal, smooth power all the way up.
When I check the EGR valve itself, as per FSM, it checks out fine.
From the reading I have done, the EGR modulator was supposed to be the problem. It clearly is not. Any thoughts as to whether this is EGR valve related or something else?
I have already gone over the whole engine with a hose to my ear and carb cleaner and water to find leaks. All vac lines are replaced and I get a steady 20 on the boost gauge at idle.
I do not want to now replace the EGR valve, which checks out fine, and have the truck still be bucking and hesitating after that $179.00 bear of a repair. (well... bear for me anyways)
truck smells strongly of exhaust when EGR modulator and EGR valve are not connected. You can smell it 30 feet away. Gives me a headache and probably won't pass inspection like this. Would like to get this fixed asap.
Thanks!
Thanks!
