Reviving an old thread here. Just wanted to report that I did this fix exactly following AppleTech's schematic in post #40 and it worked like a charm! I actually have done it twice now. Both times I achieved EGR readiness within 5 minutes of driving around.
Some background: I have a 96 that's had a P0401 that I had been diagnosing for about a year. I'm in CA and need to achieve readiness to pass smog. New modulator, vcv, vacuum lines, cleaned out intake, etc. Nothing would clear it. I eventually resorted to using this method and to my surprise I had achieved readiness before I even got out of my neighborhood!
I used a plug-in relay with socket and left the socket vampire-clamped into the ECU harness, tucked away behind the dash panels. This way I could remove the relay once readiness was achieved and then could simply plug it back into the socket if I needed to clear it again. Sure enough, a few months later I had disconnected the battery and needed to achieve readiness again. Plugged in the relay and again within 5 minutes had achieved readiness! This is the relay I used:
Amazon.com: Car Auto Truck Relay & Socket SPDT 12V 12 Volt DC 40A AMP 5Pin: Car Electronics If everything is hooked up right, you'll definitely be able to hear the relay clicking while driving around. I did not use the 100 ohm ground resistor, so the relay flutters under throttle, but regardless it still works.
After achieving readiness, I cut the lead to the temperature sensor that goes into the manifold and soldered in a 4.7k ohm resistor. I then taped the two halves of the lead together and wrapped it with some heat wrap so it looks stock. Since this mod, I have achieved readiness, passed smog, and have not had a CEL for months now!
Long-time lurker on ih8mud, but this has been the best life-saving thread I have discovered by far!
