The US M101 3/4 ton trailer weighs 1340 lb empty.
It's designed to carry 1500 lbs cross country or 2250 lbs on highway.
The early trailers do not have service brakes, only parking brakes. Given the weight of the trailer, and the payload, this is something to keep in mind.
When level, the lunette in the lower position is 21 7/8" off the ground. You need a very tall pintle setup for the trailer to ride anywhere close to level.
The military tires are 900x16, on 16x6.50 rims. These have the same bolt pattern as the 1950-1968 Dodge M37 3/4 ton Weapons Carrier/Cargo Truck.
These trailers, frankly, are best used in conjunction with a 3/4 ton 4x4 pickup at a minimum, because of the weight, ride height and lack of brakes.
The above info applies to the M101 and M101A1. They differ only in minor details.
The M01A2 would be the trailer to get if someone insists on towing it with a smaller vehicle, because it has surge brakes. It also has CUCV pattern rims (8-lug Chevy).
Shamelessly cut and pasted from another website:
M101: Five lug rims (Budd, 6.50Hx16, same as on the M37 familly of 3/4 ton trucks), 900x16 tires, brake handles have the "squeeze" trigger release and are mounted so that the move in an arc paralell to the front bed panel. Parking brakes only.
M101A1: Same as the M101 except the parking brake handles are the flip type and move in an arc perpendicular to the front bed panel.
M101A2: Surge brakes in addition to the mechancal parking brakes, hubs and rims/tires changed to match those on the Chevy CUCV's.
M101A3: Same as the M101A2 except the hubs and rims/tires changed to match the HMMWV.
