Easy Mod / Center diff. Done
Mikesta
Never decruiserfied
Missouri
Website
www.showmerents.com
Done. Easy. but hooked it up to a gray one first instead of the white one.
What is the grey one for?
RTFM
Hayes said:
I don't understand what you did.
Are you talking about adding the difflock switch?
Pin7 mod?
I'm slow.
Hayes
Hays, the mod was installing the center diflock button/switch. I didn't do the 7pin mod.
The comment above about Locking the radio almost made me spit out my coffee!:cheers:
OK. I've had a couple cups of coffee and now then engine is warmed up.
That's what I thought.
I added the center diff lock switch to my 80 yesterday as well :cool: .
It IS so easy that it doesn't really feel like a "mod."
Thanks for the switch, Dan.
I also did the Pin7 mod. Turned out to be a piece of cake as well.
Unbolted the false pedal.
Popped off the kick panel.
I didn't have to remove the ABS ECU--just unplugged it, unplugged the transmission control plug from behind, removed the appropriate wire (I just snipped it), and plugged it all back in.
Works great.
Hayes
7 pin mod... I remember reading about it once... but have since forgotten. What is the advantage in a nutshell.
I'm actually thinking about getting the free wheel hubs.
Works great.
Hayes
Total control over when the center diff is engaged--even in low-range.
My understanding of additional effects:
It also corrects for some low-range shift pattern changes you get when you install the cdl switch (and unplug the low switch at the t-case).
My understanding of the shift-pattern stuff may be a little off.
Here's a writeup with photos:
http://www.sleeoffroad.com/technical/tz_cdl_pin7mod.htm
Wow. even that mod is super easy.
PHH is by far the worst mod i've done. took 2 hours on that one
Did mine today. Took <1 hour to install the switch, do the pin 7 mod, button it all back up and road test.
I would rate this as 1/2 :banana: .
:cheers:
Dave
