For Sale East Idaho - 1996 SSR-X Gas Hilux (1 Viewer)
Year
1996
  1. Other
Mileage
170000
Color
Silver
*Update 8/12/25*
$15,000
Specs:
  • 2.0 Liter 3Y-E gas engine
    • Chain-drive engine very similar to 22RE
    • Similar fuel economy and speed as the diesels (~90hp)
  • Right-hand drive
  • 5-speed manual (G52 Transmission)
  • Power windows and mirrors
  • Push-button 4WD (auto hubs)
    • Part-time 4WD with gear-driven transfer case
  • Factory fog lights and front bar
  • Factory rear roll bar
  • 4-door double cab with short bed
  • IFS front end
  • Unmolested, completely stock
    • Factory Dunlop spare tire, never used
    • Factory double-din Toyota radio
    • Factory Toyota window rain guards
    • Factory heat and A/C, both working great
  • SSR-X Trim
  • 280k km = 170k miles
Recent Maintenance (since import):
  • Engine air filter
  • Oil & Filter change
    • Amsoil 5W30
    • Toyota filter
  • Coolant drain & Replace
    • Toyota Red Long-Life
  • Transmission gear oil change
    • Redline MT-90
  • Gear oil replaced in diffs and transfer case
    • Amsoil SVG 75W90
  • New clutch 5/25
    • Was still on the original clutch prior to replacement
    • Excedy clutch disc and OEM Toyota clutch plate
    • New spigot bearing, throwout bearing
    • New rear main seal
    • Marlin Crawler shifter seats for 4WD and Gear shifters
  • Engine belts
  • Fuel filter
  • Front and rear brake pads/shoes
    • OEM Toyota
  • Spark plugs & plug wires
    • OEM Toyota
  • Distributor rotor & cover w/ points
    • OEM Toyota
Additional Info:
Here is a well-kept, 100% stock survivor from the 90s. Runs perfect, recent service completed, ready to go another 100k miles without issue. Some cosmetic blemishes including the typical cracked dash, chalky Toyota two-stage paint fade, minor dings/dents, and a single area of corrosion on the rear passenger door. Other than the door, the chassis is amazingly clean and rust-free. Interior is 9/10, with only minor wear on the driver seat and floor mat. This truck would be an absolute monster with a 5VZ or 1UZ swap, but it also does just fine as-is and will drive highway speed.
