Early f engine carb and air cleaner needed.
Temecula, California
Hello you guys, I am in need of an early F ENGINE CARB AND AIR CLEANER. My engine is a 1966 factory F ENGINE. Please let me know if you have something. I am in need immediately and unable to find. Thanks, FJFJFJ
I've got carbs, they will need going thru, all have been sitting along time. Being a 66 it should be a element type air cleaner, I've got a few of those also. all in MT
a few pics for reference
I thought the 66 had the larger of the two small round windows carbs with the idle solenoid? Did that air cleaner come off a 66? Never have seen a non oil filter from 64 to 67. After 67 never seen a oil bath. I know the paper element were standard all the way back to the FJ25 just rarely see them. I check my 66 FSM later today to see if it has a idle solenoid.
Update: I checked a few of my early small window carbs. The smaller window is 10/67 and the larger round windows are 12/67 and 6/68. So not sure what the date for larger window to smaller round window is. Need to clean up some of the bigger window to date them. Paul what are the dates on your large window carbs? My 66 FSM doesn't show a idle solenoid but not sure I can trust that. I don't have a engine FSM to check the carb,
The '67 ONE BARREL paper element air cleaner is indeed a rare item.:frown:
