Hello,
Over the time I've been on this site I've seen a few posts about replacing the rear entertainment remote in Land Cruisers. Turns out the only two options is to: 1. Buy the part from Toyota - $$$ 2. Use a universal learning remote to copy an original remote. - Inexpensive but requires the original remote.
In this post I'll be exploring option 2 - universal learning remote - a bit further.
I still have my original remote for my 2015 LC200. But I wish to avoid the cost of replacement should the day come when I need to. ($100-$150 is nuts for a simple infrared remote) In order to avoid this cost I've purchased a universal learning remote for use in the vehicle. This means I can store the original in a safe place. Which means I have the original should I need it for future projects such as this post and/or have it to pass on to the next owner.
Why am I telling you this?
You may be able to leverage what I'e done to your benefit. I've put together a document that goes through the solution and how you might do the same thing as I have. In addition, the remote I used has the ability to copy/transfer settings via file over USB. This means another LC owner can buy the same remote and with the provided settings file have a working remote for their 2013-2015 LC 200.
(This may work on other years but one would need to test)
Remote I purchased:
Amazon.com: One For All OARUSB04G Four Device Universal Remote with Smart Control for Easy Programming: Home Audio & Theater
Settings file for remote:
Dropbox - settings.binfile
(Renamed as many browsers and virus programs flag .bin files as potentially unsafe. One will need to rename file to settings.bin after download)
Document walk-through (look at this first): (attached)
Youtube videos of how one copies the settings file to the remote:
-Note: Videos show downloading from the OneForAll Website - ignore this part since I've provided the settings file already-
Mac -
Windows -
As with anything this may not work as smoothly or as one intends. This isn't as turnkey as buying an original remote. But for a $20 alternative it might be worth a try. This is my first walk-through on here so please be kind.
One spot of trouble I ran into was I couldn't copy the file to the remote using my Mac running OSX Sierra. I kept getting a disk space error. So I had to use a Windows PC. Not sure if anyone else will run into that problem or not - but I did.
Remote I purchased:
Mac -
Windows -
