Dual Battery issues with Solar and IBS system
egypt
Hello,
i have been having some issues with my dual battery system that i hope someone can help with.
I have a standard lead acid 90 Ah as a starter battery in my 78 series troopy. connected via the IBS dual battery system, to an AUX 80 Ah lead acid battery. the system works fine and connects the two batteries when i have the engine running and the relay feels the 13.5V charge from the alternator.
I then added a cheap standard PWM solar controller connected to a 150W solar panel on the roof. The solar controller was connected to the AUX battery.
When i turn off the engine the IBS system isolates both batteries, however when i have enough charge coming in from the solar system the IBS links both batteries and charges the starting battery as well, displaying that both batteries are fully charged. yes this all sounds great till now haha.
However once i replaced the the PWM controller with a VIctron 100/20 Mppt controller the system has begun to act a little funky. in addition, I run all my loads off the load output of the MPPT controller, just to have an idea of how much power im consuming (just have a fridge and one led light running of this)
once I plug in my 150W solar panel, connected to my Victron mppt 100/20 solar controller to my aux battery,The IBS begins to feel a charge (indicated on the left bottom led 13-13.5V) but no linked led on. Then the charge drops and the relay kicks in and the linked led comes on but no charge. And it repeats this cycle every 30 seconds or so. I checked all my battery settings on the Victron app and the data seems to be correct to those set for a lead acid battery.
Now my start battery has died for some reason after not starting the car for 2 days! using an avo meter, the start battery reads around 11.5V and the aux battery is reading 13.5V, which is basically the same figure my Victron app is showing for my aux battery which is 13.7V at a float state of charge.
I even tried the link function off my IBS system and it is not able to jump start the starter battery. I have even used jumper cables between both batteries and still nothing, even tried hooking up to another car's battery, still no hope. I am starting to feel like it could be a faulty start motor on the 1HZ.
I dont understand why my IBS system is acting this way once i connected the mppt controller, and now i dont get why my start battery would die.
any help or recommendations would be greatly appreciated!
i will hook up my pwm once more to double check and see if the IBS acts the same way or differently.
thanks!!
