I am wiring up the swirching relay to a dash switch. The Automatic Charging Relay (ACR) is always on AUTO without a signal from the dash (STDP) switch. Auto mode can be overridden by the dash switch to manually combine or isolate the batteries. The switch requires power to signal the ACR.
I am considering two ways to power the control switch.
1. Run a fused power wire from the primary ACR terminal so that I will always have power to the control switch - independent of the dash fuse panel.
2. Tap into some keyed power source in the dash harness, which would provide the power to manually combine or isolate the batteries only when the key is in the ON position.
If anyone has done this, or has an opinion, I would like to hear from you.
Thanks.
Mike S
Thanks.
Mike S
