Guys, I got in over my head.
So I'm trying (failing) to install my DT cat-back exhaust on my 100 series. I've managed to get all 6 stock bolts off of the exhaust, as well as pull part of the muffler off. My current issue is with the parts of the exhaust that hold it up to the truck. I can't seem to detach these:
I've tried everything I can think of. I've used soap and water to lubricate them, I've tried a screwdriver to pry them off, I've even used a sawzall to cut off two of those points on the muffler. I decided to give up on the sawzall for one of the points because it wouldn't cut as the pipe moved around too much. But I really need input on how to get the stock pipes off and any advice on how I should put on the DT exhaust the easiest.
I'm ready to give up and I need help. Thanks guys.
