so i bought a USDA Prime Certified Angus Beef 103 rib or a bone in rib....it's got 30days of wet aging and i plan on dry aging it for another 27 days.
This one is a little over 17lbs.
first you can only dry age a good piece of meat, USDA Prime or at the very least USDA Choice (top 1/3 or CAB). Make sure the meat has at least 21 days of wet age on it before you start dry aging it.
Take it out of the cryovac and wash with cold water then dry completely off with paper towels. Get a tray with a grate in the bottom of it that will allow air flow around the entire piece of meat.
The best thing is to use one of those little dorm fridges so you dont keep opening the door, however, you can use your big fridge but put the meat in the very back and bring the temp of the fridge down a couple notches.
For the first 5 days cover with either cheese cloth or white towels in order draw moisture out of the fat. Change the cheese cloth or towels every day. After 5 days there will be a good crust on the meat that will protect it throughout the process.....
here is day 1, i'll post pics throughout the aging...
