You should always take the fill plug out before you take the drain plug out.
Probably was a good idea to go ahead with changing that? May consider relocating the breathers?
Lol yup. I Made sure it's not gonna come off again anytime soon. I think it was a little short with the lift and all.
Also, if you are going to play in water, they are a little low. We get new line, extend the rear into the quarter, near the fuel filler and the front to near the brake booster, terminate them with cheep fuel filters.
Run your extender hoses along the brake lines up to the frame. You know those are long enough to not just come undone.
Yes, just grab some 1/4" line from your local auto place and run it higher. Mine popped off all the time until I extended it.So you think I should replace the factory line with a new longer line? What I did I unhooked the line where it connects to the frame which gave it more length but technically it's just hanging there now.
Doesnt really matter.... longer and higher. Mine is up around the brake booster now.Do you remember by any chance how long the new extended line should be?
