Driving Tips for the FJ80 in Snow
Heckraiser.
You are my ninja.
Thanks for the input.
As this is my first winter here in CDA area, I'm not going t to do any "first one out" exploring. I figure if there is a lesser truck already on the trail, I'll go too. I just don't know what I don't know, and I'd rather learn in a small ditch just outside town than on a cliff in the mountains. I may consider finding a shop that'll sipe them more than they are now. If it gets ugly.
Are you asking about off road in the snow, or paved streets in the snow.. Obviously off road, having a good aggressive tread with narrow tires beating wide ones. If you are talking driving the family to a ski resort, or using an 80 as a DD in snowy weather, and if you have ABS you will find in the owners manual, a warning concerning how the ABS does not work reliably on icy roads. I FOUND THIS TO BE A GROSS UNDERSTATEMENT just after purchasing my second 80..a 93 which was the first year that had ABS.
One night heading home in a blizzard after a day of skiing. I was going down canyon just below Sundance resort in Utah and came upon stopped traffic from multiple fender benders. I was going 10 mph on new BFG KO's. I gently touched my brakes, way in advance, and my ABS totally over rode my braking input. Had I not gone to the left shoulder and used the pile of plowed snow on the left side to slow me down, I would have plowed in to the stopped traffic. I live in the mountains so next day I played on the freshly plowed roads that were still snowpacked. 10 mph on level roads and I could not stop for intersections.. I would just blow through as my ABS pulsed in resistance to my stopping input. Tires and brakes would have been just fine at 50mph but not with the ABS. Temp fix was to pull the fuse which just give normal braking. Later I cut in to the wiring coming from one of the ABS sensors and installed a cutoff switch and indicator light under the dash where I can disable the ABS without getting under the hood. The reason I used the wiring from the sensor instead of interrupting the power to the ABS fuse is that the amps from the fuse were so high it melted the insulation on the 16 guage wire so I used the sensor input which when interrupted show a "fault" and the computer turns the ABS off. My current two 80s... one LC.. one LX450 are both modified to over-ride the ABS. More modern vehicles have learned how to deal with snow and ABS.
ABS absOLUTELY sucks on my rig as well.
I've done tests showing friends and family countless times how sucky it is.
Heavy snow, deep dirt or mud; any surface you want your tires to dig into to find traction or build up a mound of mass to stop, just gunna suck.
I found that out coming down a cinder hill in my 98 Dakota. Hit the brakes, abs kicked in, started rolling my tires forward in some computer attempt to "help" me maintain control. Forced me to actually accelerate. Had to ditch my truck into a berm and damn near rolled it to avoid tail ending a quad. Yanked the abs fuse and was fine the rest of the day.
Since then, I just practice in a variety of roads to see what happens in each of my vehicles.
I hit a Prius once in my land cruiser. Sombitchwas stopped at the bottom of a downhill off ramp in a blizzard at 7,000 feet. No traffic. Just parked, in the middle of the road. I hit my brakes at the top of the ramp and felt that abs pedal vibrate as it forced a hydroplane on 3-4 inches of snow, all the way down the ramp. Tapped his bumper, another 1 or 2 feet and we'd be clear. Again, yanked the abs switch, tested it, locked the tires up, she dug down to traction and stopped just fine.
Traction control, - good. Abs, - sucks.
I hate abs, I'm just nervous about what's worse. GETTING into an accident because of abs knowing that isn't an excuse in the eyes of the law? Or being a part of any accident, my fault or not, with the abs fuse pulled, and having some attorney pin it all on me because of the fuse or switch? It's like I'm forced to put my family in greater risk of being in an accident just to reduce my liability IN said accident.
God. Hate lawyers. .
I don't think there is anything anyone can type here to help improve snow driving. The only thing that helps is actually doing it. Find an empty parking lot and play around a little. Do some controlled donuts, panic stops, etc and get a feel for it. Go out in the woods and do some snow wheelin' and find your 80's limits, you might be surprised just how sure footed they really are.
I have not driven my 80 in the snow yet... The ratio is 60% Tires, 30% driver and 10% car based on my experience driving a variety of cars with similar and same tires in the snow.
stopping and turning is defined by the tire, everything else is, is the driver abusing the limits of the vehicle.
I used to drive my jetta, my gti, and my mazda 3 on icy snowy highways and most of the vehicles in the ditches are trucks, h3s, and the odd subaru... not saying that's not easy to loose control, but you have to be abusing the right variables at the same time.
Are you going too fast for the conditions?
Are my tires made for this condition?
Last time Fort Worth iced in, and it was a bad one, I had no problems getting out and about on my KM2's. Actually thinking about what i am going to get for the new 80 since we seems to have a couple ice days per year. Last year was a bitch with think, cobblestone, ice everywhere.
......... The ratio is 60% Tires, 30% driver and 10% car based on my experience driving a variety of cars with similar and same tires in the snow.......
Where do you get your figures? If I was to guess, as I think you are, It would be 60% driver, 30% tires and 10% rig. The driver is the decision maker in the formula and hopefully using common sense.
.......stopping and turning is defined by the tire, everything else is, is the driver abusing the limits of the vehicle.......
Agrees more with my formula than yours
.....I have not driven my 80 in the snow yet......I used to drive my jetta, my gti, and my mazda 3 on icy snowy highways.......
As I hope you've already seen - your 80 handles a bit different in non-slick conditions, than these other vehicles you mentioned. The 80, being a heavier rig with a higher CG, will be much more difficult to recover control if you exceed it's limits on icy roads.
Best part of your post. The painful truth is that experience is the only way to know this. We do our research and make our decisions and choices based on that and hope we are prepared. Expect the unexpected, don't assume any other driver is in control both ahead of you and behind, and be ready to get out of the way at all times.
Nice looking rig - looks like we're not too far apart. Only thing that I would add to your post is caution to your last sentence:
"Go out in the woods and do some snow wheelin' and find your 80's limits, you might be surprised just how sure footed they really are."
is this - 1st time you go snow wheelin', don't go alone. Make sure there is another rig or 2. You might exceed the limits to the point of needing help. 10 or 20 miles away from help by yourself would be a bigger surprise than discovering how sure footed the 80 is. Attached pic is my 80 with front DS tire buried in a "surprise" hole. I was on a club run so a tug from behind easily got me out of this.
I pulled the figure out of thin air, you're absolutely right. I was trying to use those percentages to relay my opinion that tire choice is the defining factor in stopping and turning a vehicle in the snow.
to be honest, I drive the 80 quiet conservatively, due to it's size, and way slower pickup than the other vehicles, also we haven't had much water or snow so far this year since I bought the car, once we do I will try to see how it handles.
good advice on your part, and I agree with you 100%
