Have a weird problem and I've searched for answers but found nothing that matches what's going on.
For some reason my Driver's side tail light isn't working. I've looked over all the harnesses, unplugged and put dielectric grease on them. Everything is so clean and free from corrosion I can't figure out what it is.
So basically the passenger rear tail light works and brake light works well. The drivers side light would work but when applying the brake, the tail light would go out. Now with everything apart and both tail lights out, I noticed that when I put a new bulb in the bottom tail light on the drivers side, the passenger tail light lights up as if the brakes were on but no driver's side tail light.
Not sure if it's related but all of the sudden my driver's side window goes down but not any of the others and at one time they all worked perfectly. Not sure if there's a short or a bad ground but all wiring is almost like new and free from corrosion. The entire truck only has 150,000 miles on it and is free from corrosion.
I do have a trailer lights from the OEM (inside passenger rear fender) and all seems corrosion free, not wet and tested with trailer module disconnected and same results.
Anyone ever encounter anything like this? I'll get pics if needed. Any advice would be helpful.
