Driver door lock Actuator issues
New Jersey
My driver door lock actuator failed and I just replaced it 2 days ago. It unlock/locks with keyfob fine initially, but yesterday when we were away from the house I found a weird issue. When I hit the lock button, there was a weird beep and all the windows and sunroof opened. I closed the windows and tried again, the windows all opened again. If I log my GX from the inside then it stays locked and the windows dont open. I also notice that my key doesn’t work in the door since the new actuayor change. Is there a pairing that I can do on my own, or is this something that only a lexus dealer can handle?
Now if I lock from the inside, all the windows open and the car unlocks... it only locks if I click the keyfob once... any thoughts?
I just took apart the door and found that the key lock was not sitting in the actuator. It was a simple fix and only had to loosen the t30 bolt from the door. Once loosened I could pull the lock and slide the + end into the actuator. I guess if that doesn't line up, the GX must open all the windows and sunroof as a warning...?
