I have lots of rotational free play in my drive shaft. Not in u-joints or splines. At the transfer case end. It must have been discussed here before but I cannot find any thread about it. I guess I suck at the use of the search function. Any help?
I wouldn't think so, but it can eventually break your parking pawl inside the tranny, which is spendy/time consuming to replace, not to mention the dangers of having your rig fly down a hill with nobody inside.The free play is about 15 degrees. As jonheld says it is a bit less in the rear than the front.
I suspect you guys will say that it is 15 degrees is normal but when I bought the truck 40,000 miles earlier it did not have any noticeable free play at the drive shaft. Now the truck has 175,000 miles.
Can the free play be caused by frequent parking on a steep slope without using parking brake (only gear box at Park)?
