- Thread starter
- #21
How does that site work? I think you need a login to access it though.
Imola Red said:I can read it and that is the way I have it hooked up but the head unit won't power up. DAMN!
I don't have the speakers hooked up yet but with power going to the stereo it won't power up. Might have a bad unit, it's brand new though.
hoser said:Also a nice place to put an ARB flexi water tank-- holds 25 liters of water... or liquor.[/QUOTE
Have you seen one of these in person hoser?? I am working on some sort of freshwater system 5-7 gallons with a pump and hadn't seen these yet. Gonna have to check price, cool if you added a 12v pump.
end hijack\
LonghornCruiser said:I think I remember have power troubles when I installed my stereo. I ended up running a heavier gauge power and inline fuse that solved the problem. Should be done anyway to make sure that the new unit gets enough power. The factory unit has no internal amp, whereas the new unit does. To me, that means the new unit draws more power and the factory wiring can't push enough.
jahmaka said:I think the radio 12v comes from the amp.Check at the amp with the plug disconnected for the power.With the the plug disconnect,check the wire at the radio for the 12v.If their is no power,what you have do is check which wire has the 12v coming out of the amp.then remove the plug and tie those two wires together to get the power at the radio.
Make you have acc power too if not the radio will not turn on.Grd the radio to the steel bar right behind the radio,don't use the grd in the wire harness.
Imola Red said:Great idea. I'll try that or I might just re-run the wire.
Thank you for all the great info.
Hope all this helps others who are crazy enough to replace this thing on their own. :whoops:
I have not seen it in person but I have ruled it out for me since I have the rear A/C back there. Refer to this water storage thread. I like that its just gravity fed, making it simplier, cheaper and more reliable. However, a stainless steel water tank that uses your compressor to pressurize the tank would be cool too.hoser said:Have you seen one of these in person hoser?? I am working on some sort of freshwater system 5-7 gallons with a pump and hadn't seen these yet. Gonna have to check price, cool if you added a 12v pump.
bamachem said:Ok, I have all the wiring sorted out at the amp. It turns out that on a 2000, there is a 14-pin and a 16-pin clip. the 14 pin is for the signal from the headunit to the amp along w/ the dimmer, amp turn on lead, and some other stuff. The 16 pin has larger gauge wire and has the power for the HU and amp from the fuse block, the main grounds for each, & all the wiring from the amp out to the speakers.
The most interesting thing about the whole thing was that the speaker leads from the Head Unit down to the amp was 5 wires - 4 seperate positive leads and a common ground. That's the thing that threw me the most. Once I got that figured out and figured out the dimmer, then I had it made.
I'm VERY happy with the sound quality w/ the Alpine amp in there and the 4 6.75" coax replacements. I can't wait to add the 8" kicker solobaric...
