Thanks for the great response. I wouldn't run the 37 on the trailer. I'd replace them with some 30-31". My only concern then is the width of the trailer compares to in inside of the wheels/tires on my axle. I will check that width this weekend and compare that to dimensions of the trailer's width I find online.#2 would be the slickest result. But there is a problem... Fenders. I don't think they're going to work with 37s. I suspect the M100 is pretty similar to my M101 CDN. You can go as tall as 33s and you're OK to run, even if the fenders aren't wide enough to be legal. .
From some rough measurements that I took awhile ago;
spring pin to spring pin =~36.5", Spring pin to end between 7 & 8."
I hope to be working mine Saturday if you need more precise measurements.
Couple of things to mention;
Mine has left hand lug nuts, don't know if all of them are like that.
In case you didn't know, the M100 has parking brakes. Tt seems like your handle is missing but the drums and cable seems to be intact.
Thanks. I will take a look at those this weekend. unfortunately it is a busy work Friday.Dan, Don't know if this will help, but I found images of the M100 manual online: http://operatormanuals.tpub.com/TM-9-2330-201-14/index.htm Here's the page with the data on measurements: http://operatormanuals.tpub.com/TM-9-2330-201-14/TM-9-2330-201-140014.htm I suspect Charlton's help may still be needed with things that aren't covered on the data plate, though.
Charlton,
Were you able to confirm the centers for the axle spring perches and their width?
Yes, unfortunately I was a little off.
I was trying to measure the distance between the bottom of the spring pins but it was kind of difficult by myself. I came up with 36 1/8 (centered). I think that the manuals spec of 36 1/4 is what you want to go by. Given the size of the hole in the plate, I think you could easily get 1/16" of play from each side.
The U-bolts are 3/8" thickness, 2 3/4" wide (from center line)
The springs are 1/3/4 wide, the u-bolts are spaced 2 1/4 from each other (from center line).
The side of the trailer and the outer side of the outer u-bolt are close to being on the same plane. Meaning you can use the outer u-bolt to determine if your wheel/tire backspace is OK.
Let me know if you need any other measurements![]()
Dan,
I used some HF magnetic lights when bringing home our M101 CDN from Iowa. Stuck 'em on the sides of the box, but thought to zip-tie them, too. That was a good thing, as the magnets just seem a bit weak to stick to a bouncing 1/4 ton trailer and at least one was just hanging when I got home.
The roads you're bring your trailer back on are probably even less smooth. Probably best to plan on the magnets doing most of the sticking, but also have a backup plan to attach them better -- or at least not leave them bouncing along the pavement.
Thanks.
I have flat towed my 40 before and even though I mounted the magnets on a flat surface ( my rear carrier) they fell off the first at some point and dragged long enough down the road to short out my tow rig's brake light fuse. I bought a new pair and have zipped tied them ever since. Great minds think alike.
Dan
Fantastic. Hopefully the curved fenders can handle up to a 31. Just depends on what I come across.
Oh shoot. Maybe next time your out there, take a measurement of the thickness of the perches. No rush. I have till spring. Hate working in a freezing garage.
I get a chance, I'll measure how much room is under the fender. My work is crazy busy at the end of the year so it might be the weekend before I get a chance to get out there. I think the worse case for 31s is you might have to go SOA.
As for the perches, are you looking for thickness of the steel or other?
