If the part # is the same I would be shocked if the ECU tuning is different. The point of part #s is to categorize the differences, and Toyota has dozens of part numbers for similar parts across many vehicles even for extremely subtle differences. If there was a difference, there's no way to tell if you have put an LC ECU into an LX, which would be a nightmare for Toyota repairs.
Even if there was a different firmware tuning depending on LC vs LX, Toyota would have a different P/N for each ECU so that you couldn't apply an LX firmware to an LC (or vice-versa) and the firmware would verify the P/N is applicable before applying. As a software guy, I can tell you that if you try to apply the Dell 5150 firmware to your Dell 5100 laptop it will NOT work, and years ago the firmware developers realized they needed to check the hardware you were applying that firmware to before they actually applied it, lest you end up turning your $1,000 laptop into a very expensive door stop.
We only have 93 octane around here not 91. For an LX should I go mid grade 89 or just pump the 93? Let me ask it a different way. Will the two extra octane be a waste or will the 89 not be quite enough to take advantage of the program on the lx?
As a software developer, you would also know that often, the same hardware and software baseline are installed to many different deployments. And a software config or switch may detect the deployed context and select the right maps and settings for that platform. Not hard to do these days with so many matrixed sub-components and sub-computers on a vehicle, for which the LX likely has unique or uniquely identifying ones. Replacing an ECU generally requires a VIN to be registered via Techstream, along with a specific procedure to to initialize, as the the ECU also has to be registered with the immobilizer and key which are certificate based. None of this is an end user thing and requires dealer only IP. Basically lots of opportunity for the right config/maps to be enabled. So the fact that they share hardware ECUs really proves nothing.
I've never tried to register an ECU or download the firmware, so I'm not familiar with the procedure. But if there's any potential for difference between the LC and LX ECUs I would still expect Toyota to provide two different part numbers. Yes the ECU developer could rely on some other system to indicate it's an LX instead of an LC (i.e. "if hasAHC()==true && hasPowerLiftGate()==true then applyFirmware(LX) else applyFirmware(LC)") but it would be really bad practice to do so. Imagine in the (totally fabricated and hypothetical) above example if the Aussie LC has AHC but not a power lift gate and then someone in marketing decides to add a power lift gate as an option, and suddenly the ECU mapping changes for all new vehicles. Any time you're relying on external systems/indicators you break the containerized model and risk affecting other systems you weren't expecting, particularly in something like an ECU which might have hundreds of thousands or even millions of lines of code. IMO Toyota's electronics are generally extremely reliable simply because they dont' intertwine them unless absolutely necessary.
Again, admittedly I don't actually know how Toyota's ECU installation works. I would have assumed that a replacement ECU would come with firmware on it already and you could install a new ECU from Toyota without applying a new firmware if you so desired (though there may be reasons to apply a new firmware). Even in my world where a multi-million dollar EMC storage array requires a technician to burn a .bin file into the array before we can use it the controllers still come with a base (uncustomized) firmware applied. I would be shocked if the ECU firmware is actually different between the LX and LC.
Arguably the scientific way to answer this of course is to dyno an LC and an LX on regular and premium fuel and see if there is any measurable different in HP. Alternately if someone had access to an LX and an LC ECU firmware for the same manufacture dates it might be trivial to determine if they're actually the same.
You're trying to make a case based on your layman assumptions. And furthering those assumptions based on more bad assumptions. This is like those endless oil forums where some layman end user thinks he knows better than the factory to run some other oil weight because it gives him better gas mileage (at the cost of engine wear). The factory spends millions validating exactly what will ensure the motors output, efficiency, and longevity. It states explicitly in the manual what the potential impact is of running 87 octane under load.
I'm telling you, I've been in the world of tuning, flashing, and actual manipulations of maps. Dyno tuning, and output differences. Knock is a real thing with the wrong octane. Modern cars have so many different maps, that they switch between based on incredibly subtle differences. You may know that VW with diesel gate changes behavior based on things one would have never considered like steering angle. To think that the same part number ECU couldn't key on something that you might not have considered, or that procedural installation of an ECU couldn't toggle a mode or config, is short-sighted. It could be that the same ECU is completely backwards compatible in both models when being repaired, yet LX's coming out of the factory are indeed configured or setup differently.
Sorry if I feel strongly about this as this is my wheelhouse of tinkering. It's just incredibly funny to me for owners of 80k++ cars to save money over comparatively trivial monies.
Another member posted this question to Toyota with a not very helpful response:
FYI for anyone that is interested, I posed the following question to Toyota:
ES | Detailed Specifications and Lexus Certified Pre-Owned – Model Library – ES 2010.
As the engine is the same in both model years, this change may be due to fuel map adjustments necessary to allow the use of 87 octane fuel, or simply due to the fact that 91 octane fuel has more energy per gallon than 87. We apologize that we do not have technical information on the specific differences between vehicles that share the same engine block.
As to your question regarding research octane numbers, this is the most commonly used unit of measure for rating fuel in markets outside of North America. You might consider the relationship between research octane ratings and "normal" octane ratings to be analogous to that of gallons and Imperial gallons when discussing volume.
Toyota can only recommend that you use the type of fuel that is specified for your Toyota or Lexus in the year that the vehicle was built. Use of 87 octane in the Lexus LX 570 may cause engine knocking, which may over time cause damage to the vehicle. Damage caused from the use of non specified fuels may not be covered under warranty.
6/
The fact is, assumptions are being made because Toyota has not come and and said what accounts for the difference.
On another thread, someone reached out to Toyota, and received a not very helpful response:
Query to Toyota:
The Toyota LC and the Lexus LX are both URJ200 vehicles utilizing the 3UR-FE engine.
For the LC200, the engine specifications are:
Required octane: 87
HP: 381 @ 5600
TQ: 401 @ 3600
For the LX570, however, the specifications are:
Required octane: 91
HP: 383 @ 5600
TQ: 403 @ 3600
Both engines are manufactured in Japan as opposed to the Tundra/Sequoia 5.7L engine which is built stateside.
The question is, why the difference in required octane, hp and torque figures? I'm especially interested in the octane requirement as page 90 of the URJ200 manual states, "Use unleaded gasoline. (87 Octane Rating [Research Octane Number 91] or higher)".
Second, what does "[Research Octane Number 91]" mean?
Response:
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We appreciate the opportunity to address your inquiry.
While we understand that the Toyota Land Cruiser and the Lexus LX 570 are similar vehicles that share some mechanical components, each Toyota vehicle is designed to its own set of specifications. Vehicles that share engines may be tuned to different standards depending on their specific engineering goals and intended use. Additionally, differences in engine bay and transmission design may necessitate changes to the layout of the intake and exhaust systems in similar models, resulting in differences such as those you have brought to our attention.
Perhaps speaking more directly to your concern regarding Octane Ratings, Toyota's published horsepower figures are based on the recommended fuel for the vehicle. You may be interested in comparing specifications for the 2011 Lexus ES 350, which requires 87 octane fuel, and the 2010 model, which required 91. As our recommendation changed, the 2011 model's output was lowered to 268 hp @ 6,200 rpm from 272 hp @ 6,200 rpm. Details for both model years can be viewed at ES | Detailed Specifications and Lexus Certified Pre-Owned – Model Library – ES 2010.
As you can see, the response states that it could be based on fuel map adjustments, or it could be due to the fact that 91 octane allows more compression to get better use of the energy of gas (their response that 91 octane has more energy is not accurate).
As you can see from the ES350 example they give, the difference in HP between 87 and 91 isn't far off from the 200 to LX. So I will also make an assumption that rather than do a different fuel mapping that would only give 2hp, they are mapped the same, but the difference in octane gives more output. I also see a small gain in mpg when I run 91 in my 200.
Good info but if your conclusion was correct it would state premium fuel recommended not premium fuel required? Right? They wouldn’t be talking about engine damage in the LX and then recommending 87 octane in the Land Cruiser if they’re the same?
The octane change in the ES 350 from 2010 to 2011 in the manual is "required", even though they are the same setup, but the HP changed by using a lower octane.
Well then the required doesn’t make any sense
I agree, and that is the point. The ES required a certain octane when a different octane would simply change performance. Unless they want to show higher HP numbers and there is a legal requirement to require the corresponding octane to get to those numbers. My 03 V8 4R manual stated:
For improved vehicle performance, the use of premium unleaded gasoline with an Octane Rating of 91 (Research Octane Number 96) or higher is recommended. They quit adding this phrase in later model years.
If it were a large difference in HP, I would think advanced tuning or fuel mapping is involved, but for two HP? Logically, it seems the gain from advanced timing due to higher octane would be the cause for that vs. different fuel mapping.
I also saw someone that asked the question about an identical model sold between the U.S. and Canada. The Canada model required a higher octane than the U.S. model, even though they were identical. Sounds crazy, could Canada have different requirements? The LX is sold in Canada and the 200 is not. Normally I would not consider that except for the question raised here:
Why would the exact same car call for gasoline with a different octane reading in Canada?
I agree, unless they want to show higher HP numbers and there is a legal requirement to require the corresponding octane to get to those numbers. My 03 V8 4R manual stated:
Also, the Lexus website states:
383hp*
*Ratings achieved using the required premium unleaded gasoline with an octane rating of 91 or higher. If premium fuel is not used, performance will decrease.
Well higher octane give you better EPA numbers?
Even Toyota/Lexus only claims a "power gain" of about 1/2 of 1% between the two specs.
Surely one isn't likely to bump up one's MPG a full 1 MPG with only a 0.5% increase in power.
As for gas expenditures...the deal on Premium is grim...
As of today, December 19, 2017 in the US:
Average price of Regular fuel: $2.421 per gallon.
Average price of Premium fuel: $2.974 per gallon.
So for about 0.5% supposed increase in power...one must pay (based on current average in US) about 18.6% more.
Crappy deal if ever there was one.
I've tested literally 60 - 80 tank-fulls (probably still have the notes and spreadsheet around here on an old computer) of various brands of Top Tier 87 and 93 Octane fuels in my GX 470, LS 430, and LX 570. I always tried to drive the same way on all fuels in order to make the testing as valid as possible. NONE of these vehicles showed a statistically significant MPG increase on 93 octane vs. 87. On some tanks mileage was actually better on 87 (not really surprising to me). The LS seemed to show perhaps a tenth or two MPG improvement with 93, but I'm not sure. I feel like I wasted my money, but nevertheless I ran 93 octane in the LS except for the ~10 tank-fulls of test fuel.If you want to test for yourself, run a couple tanks with regular and then a couple with premium. Ideally with similar driving distances, terrain, etc.
