Does anyone know aux lights with high beam
Does anyone know where I can tie into the high beams to use aux lights? I’m looking for the spot before the dimmer for the running lights. I’m looking to use my aux with the high beams.
You talking about the factory fog lights or aftermarket lights? There's a thread, maybe in the FAQ, on wiring the factory fogs to be used while the high beams are on, probably similar wiring for aftermarket lights.
So from what I understand is that you have to tie in to the relay before the system tell the light to dim. But I’m not sure where that is. I figured someone has accomplished it
