Oh yeah, the same damn questions huh? sorry but I'm abit worried over this volvo pump and wan to ask folks if it is the right one. Does the steering box look right? thanks Ken
It will be fine if he uses a Bill Dorry mount for the pump.
I don't know, but I been told, Bill Dorry aint no more.........
Yes I've got the Dorry mounts for a mini-truck conversion and just about ready to go.
I'm wondering about mounting and shaft size of this pump. the shaft size is the same for all GM press-on pumps of this vintage If I replace the unit with a rebuilt unit should I order on for an 81 Volvo 240 DL or are these sag. pumps pretty much all the same?Pretty much all the same, save the return line fitting
Bushing? Is it a bearing or a spacer thing to get the pulley to mount on a sag pump?I call it a hub, a press-on hub, and you won't get one with a reman pump so reuse the old one
The pulley has 4 bolts on the face, is this the right one everyone talks about? I hope it is, I hate to have pissed away $20.You didn't piss away anything..........yet
In regards to the picture above (Degnol) my low pressure line enters at the middle of the tank. Does it make a difference? I'm going to try and hammer out the fitting BS before I swap out anything what lengeth of high and low pressure lines do you all recommend. the high pressure line on the sag pump was the same as the mini box in my case. I used two 90* fittings and IIRC the hose was 19.5" from the center of the 90's I'd love to have this ready to roll and tear into it by the weekend so I can enjoy driving it as soon as the box is fitted. Go! Cat....GO! Thanks Ken
Well.................that does not mean there are no more of his mounts out there...................phucker
Ed
What did this pump come from?
It would help immensely with my current swap.
