I would have hoped they would be similar. My mindset being like other auto manufacturers what to keep production cost down by using the same parts on same series vehicles. Thoughts?
I used that on my Ute.And some of the Australian vendors sell these for the 75 series. They may be the part you need as they are only the part where your feet go.
About $105 AUD each TOYOTA LANDCRUISER 75 SERIES 1984 - 1989 FRONT FLOOR PAN REPAIR PANEL RH - Australian Made - Aveska
good.What was the fit like?
the floor under the front seats of the Ute/Troopie is higher, therefore the seat legs are shorter, due to the main fuel tank located under the front seats. All other models have the main tank in the back of the vehicle.I had always thought the 7* series all had the same floor pans as in that rust replacement panel but differed from the seat mounting back. There is no part number from Toyota because I don't believe they make anything like this
Those particular panels I would say should work on all floors, you might have to trim some to fit at the back, maybe.I know they are higher under the seat, but the actual part of the floor where your feet touch appear to be the same , which means those rust panels may suit all 7* series
The main tank is under the floor, unlike the 40’s where the tank sits under the seat and on the floor.Hmmmmmm? Maybe just maybe that wouldn't be a bad idea after all? Then installing the Ute/trooper fuel tank under the seat? Run two tanks... just dreaming is all.
