I recently acquired an 82 FJ60 with 128,000 miles per PO and odometer. There is a noticeable and somewhat loud tapping noise that seems to originate from where the distributor enters the engine. The noise increases with engine speed but does not get louder. The noise does not run the entire length of the engine, only at the area of the distributor. I am wondering if it could be a bad tooth on the cam gear that drives the distributor or if it could be the distributor itself. Any thoughts on this before I pull the distributor and try and look at the teeth on the camshaft. Thanks in advance.
