dipstick
Given that the part that broke off sits in the oil, and the oil sits below the crank, I doubt there is any real concern. It's not going to go through the oil pump pickup screen, it'll just sit in the bottom of the pan till you pull it off to change a leaky gasket.
Wonder if it met something in the case that helped it break off...
t
I was thinking a counterweight... but... really, anything rotating, I guess...
t
Y'know, the outer part of the dipstick tube is just a press-fit into the block, if you bump it accidentally you can knock it out of line..
