You normally can find someone to set the (rebuilt) the rear 3rd for 200 /250 bucks.I just under went a horrible situtation. I had someone put a completely new rear end in my truck and it did not fix the problem
How much does it usually cost to check the settings and put new seals and bearings in a rear end at a decent shop.
Tell yea what WHY DON'T YOUIt was and is know has a loud noise/ small vibration coming from the rear end. Two people told me that rear end was worn out. Needed to get a new on.
The noise only comes in at 30 to 60 mph. I am going to get my drive shaft off take it to a shop and have them check the shaft and the u-joints. I am also going to drive the truck with out the rear hooked up and see what it will do.
Or just buy some low mileage diffs from someone like me.....Shipped to your door will be way less than sending yours out for rebuilding...
*Edit* Whoops, I misread your post and thought you said 30 AND 60 mph. Oh well, here are some thoughts anyway...
That sounds like the vibrations I got right after my OME install. I would get a strong vibe @ 40km/h and 80 km/h and a weak vibe at 60km/h. I attributed it to vibration caused by changing the angle/arc that the U-joints travel through (thus, needing to "break in" again). I suspect the speed dependancy stemed from harmonics in the springs that coincided with the produced vibration at those speeds.
It went away after a few months. Not saying that is what it is in your situation (or mine for that matter) but it seems I was aware of this before the install, so I *think* it is a reasonable guess.
The fact that is comes at certain speeds (which are harmonic, i.e. 60 is double 30) tells me that it is the natural frequency of something amplifying the vibration.....
