diesel H motor- filter question
kkt
ATL. GA.
Does anyone know the correct oil filter for this motor. Any brands/ I have heard it is the same filter for the 2F motor?
My 2H has been running with a Wix 51627 for most of its 430,000 kms. The motor is still tight and doesn't need extra oil between changes so tghe Wix must be good. :)
This filter is much larger than the filter on the 2F.
For a fuel filter I reccomend a Racor filter/sedimenter added on to the passenger side firewall. The original bolted to the frame under the passenger seat is prone to rust-out and not as easy to flush.
IIRC the H motor uses an element type of filter, but I'm not sure. Does it have a long bolt running through the filter?
Dave
Yeah, if you are referring to the "H" rather than the "2H", then you definitely require an element filter. There is no spin-on nor any way to easily convert to a spin-on filter. I get my filter elements and O-rings from Marv Spector.
H motors are also supported by Toyota Industrial Parts, the forklift and tractor division in the US. It could be worth to call to their local dealer for a price.
Dave
If this is for a 2H then the Toyota part number is 15600-41010 and I got one at a dealer here in norcal.
I would like to see the mounting set up on that Racor... do you have a pic?
