While I'm searching through the extensive archives maybe someone will be able to shed some light on this one. I just turned 100K on my '96...actually 101K. Last week-end in Vermont I returned to the truck after snowboarding and when I went to start the truck it sputtered and coughed but did eventually start. Haven't had a problem again until today when I went out this morning and started the truck cold. Same thing but coughing was more like choking. It wanted to start but just couldn't after a few seconds of cranking. On attempt two it started without any of the previous symptoms whatsoever but idled a little rough for a minute and belched out a rather large cloud of grey/white smoke from the exhaust. After a minute or so I drove off and everything seemed to be ok....what gives???
For a little history I am do for an oil change (Mobil 1 5w 30) 6000 mile intervals, and after checking the oil at 6100 I am about a quart low. I check every 1000 miles and it was fine at 5000. I also replaced the O2 sensors about 1000 miles ago after resetting the CEL P0130 about once every two weeks for over 1 year. Truck runs perfectly smooth and idles normally. I had my oil analyzed at 94K by Blackstone and they said there were no signs of abnormal wear whatsoever and that I could increase my intervals if I desired. I did a tuneup with cap, plugs, rotor and air filter at 89K, and starter contacts at 72K. I've also flushed the coolant with Toyota Red and swapped the PHH. I have not yet changed the fuel filter since I purchased the truck with 70K...hmm I wonder.....
Any thoughts?
Now for the unrelated chain of events that is probably somehow related along with the position of the moon....I purchased FIAMM horns to upgrade the crappy OEMs and stupidly blew the round underhood horn relay as the FIAMM insulators are not really insulated so I've been without a horn as a result for about a week. I also finally installed the second fuse block inside the truck under the dash to run off of my second battery and I discovered the other day that the second battery is not charging as it always has in the past. I am now running the second fuse block off of the marine switch output on a solenoid relay setup a la Christo's schematic....probably can't do this because of a cutoff for charging....anyway I also found a botched up crease behind the driver's side second door with rust....fawk! This is the side that was repaired by some shoddy body shop and the PO so I am hoping it is ok.
One step at a time though...the coughing/choking is the top of the list. I do have the flu right now so maybe I gave it to my 80. Thoughts while I search the archives?
Any thoughts?
