SOLD DFW TX: 1987 FJ60 H55F (price reduced)
Year
1987
  1. 60 Series
Mileage
277000
Color
White
Outside Link
https://www.facebook.com/marketplace/item/1745579128983552/
More updated pics coming soon. Lots of new parts- suspension, brakes, etc
$17,000
At a glance:
-5 speed
-Low rust
-Frame in great shape
-BFG AT 31x10.5r15, excellent tread
-New interior
-New brake system
-New suspension bushings & shackles
-Rebuilt T-case, rear driveshaft, knuckles repacked
-All new fluids
-AC & heat work great
-Fresh inspection & registration
-Clean title in my name
Now for the details:
Body:
The body is pretty low rust for a 60, but still has some rust spots to be aware of.
-2 small/medium holes in passenger floor
-Rust at rear quarter arches
-Pinhole areas near rear floor board
No rust on roof or rain gutters. There are some early signs of rust in this area but no bubbling, only staining. The next owner should seriously consider redoing the seam sealer along the rain gutters to protect those seams.
Bottoms of doors are good, no rust on tailgate, no rust on rear window.
New driver's floor welded in.
There are numerous dings and dents, including some large dents on passenger doors from rubbing past a dirt mound or soft log I’d guess. There are some considerable dents on roof from loading something heavy onto it. There are numerous paint imperfections. PO sanded down some areas that had scratches and never painted it.
There is some evidence of bodywork and paint blending on driver’s door.
New Touge Nation stripe kit installed in June
Frame:
Frame looks to be in great shape, no appreciable rust or holes.
Early style ARB bumper
Interior:
New DNP carpet and CCOT seat upholstery.
Good condition center console.
New Speedo cable.
Cargo area in pretty good shape, just some wear on panels. Headliner in good shape. Rear seat operates as it should. Middle rear seat belt needs repair, missing buckle.
PO spraypainted interior floor, not sure if it was an attempt to hide rust or what, but the biggest rust repair has been handled.
PO cut holes in rear door cards for speakers.
All windows and Locks work. Locks could use some lube
Crappy window tint separating/coming off.
Engine
Engine came to me with low cylinder #3. After valve adjustment and consistent daily driving, the cylinder has come back. Compression numbers coming soon.
Oil pressure very healthy, verified with mechanical gauge.
Have driven it to colorado and back, engine worked great.
PO installed aluminum radiator, DUI electronic ignition, headers, and desmogged the vehicle.
Small leak from RMS or engine pushrod cover. Leaves a coin sized drop after parking.
Carb runs great.
-new air filter
-new air pump delete pulley & belts
-new valve cover gasket & grommets
-all new fuel hoses, new fuel filter
-new spark plugs
-exhaust header wrap on cyl #1
-all new coolant hoses
-rear heater bypass
-timing cover seal
-new harmonic balancer and front main seal
Drivetrain
  • Transfer case cleaned & resealed
  • new speedo gear
  • new speedo cable
  • new clutch master & slave
  • gearbox feels high mileage but no real issues, just not smooth as new
  • rear OE ujoints, rear shaft rebalanced
  • front shaft needs new grease plug
  • hi-lo selector lever needs washer/shim
Suspension
  • OME lift, new SOR bushings and greasable shackles.
  • OME shocks
  • Tires have 7000 miles on them. Matching spare.
Steering
  • All new 555 tie rod ends
  • new PS pump & hoses
  • new gearbox input seal
Brakes
  • New front rotors, pads, hardware and calipers
  • All new hoses
  • New master cylinder
  • New wheel cylinders, shoes and hardware
    • Rear driver wheel needs self adjuster pin changed out. Over tightens after a while
Electronics & Misc
Bluetooth radio installed. Antenna not connected.
Wipers are a little slow on higher speed settings.
More updated pics coming soon. Lots of new parts- suspension, brakes, etcView attachment 3124684
$18,500
At a glance:
-5 speed
-Low rust
-New interior
-New brake system
-All new fluids
Body:
Frame:
Interior:
New Speedo cable.
Engine
Carb runs great.
-new air filter
-new spark plugs
-rear heater bypass
-timing cover seal
Drivetrain
  • new speedo gear
  • new speedo cable
Suspension
  • OME shocks
Steering
Brakes
  • All new hoses
Electronics & Misc
View attachment 2921003View attachment 2921004
Is this still available?
$18,500
At a glance:
-5 speed
-Low rust
-New interior
-New brake system
-All new fluids
Body:
Frame:
Interior:
New Speedo cable.
Engine
Carb runs great.
-new air filter
-new spark plugs
-rear heater bypass
-timing cover seal
Drivetrain
  • new speedo gear
  • new speedo cable
Suspension
  • OME shocks
Steering
Brakes
  • All new hoses
Electronics & Misc
Still $17k?
Hah, yeah but been thinking about increasing it. I still kinda want to keep it! Been almost 2 years of owning it lol. 17k is the "you show up at my house with the cash and don't even give me a chance to think about it" price, but you're more than welcome to send an offer, just know that I'm not super motivated to sell, it's my daily currently
Gotcha. Well I think you should keep it and enjoy then!!
What made you want to sell in the first place?
I never 100% wanted to sell. But I bought it with the intention of not keeping it long term... so I'm in a weird spot. I bought it with money that I should have put into home improvement, etc. So I figured I'd list it for a price that I wouldn't say no to.
Main issue is I want a red or brown or blue 60. But lately I've just entertained getting multiple..? Might be a bad idea lol
Like I said, if you have an offer that you stand behind, PM it, worst I can say is "No thank you"
Still for sale? Can't send you a PM unfortunately - getting a "max inbox limit" error.
It is still 'for sale' yes, but see messages above. I'll clear out my inbox now, thanks for the heads up
Nice Rig - GLWS. I think it's a fair price!
Who have you used in DFW to maintain it or just turned wrenches yourself?
the vehicle I was interested in sold... PM me with offers.
Will be driving it to radwood austin this weekend if you want to come see it (and a bunch of other cool 80s/90s cars)
