SOLD DFW: Brand New OEM JDM clear corner lights and connectors 98-02 LX470
DFW
  1. LX470
Brand new OEM JDM clean corner lenses for 98-02 LX470. I’ll also include all the parts to convert it to work with the factory turn signals. Only thing you’ll need are the bulbs. All wires, plugs, and connectors are OEM from Toyota. I’ll also include a brand new first aid kit. You know in case you cut your finger while installing them.
Asking $225 for everything if picked up. $255 shipped.
Price reduced to $200 picked up and $230 shipped.
They’re all clear and take a different bulb that is all. You can slip your wires out of your factory plug and push them into the new connector. Easy and all Toyota.
Do you know what the difference in the housings are between these and a 03-07? The part numbers are different, but I can't figure out why.
The part numbers vs the clear ones that Patch used to sell are different though is what I'm getting at - sorry, wasn't clear about that originally.
I didn’t read the thread fully or I would have caught that, my bad. Would be cool if they were glass🤷🏼‍♂️
So will those socket plugs part -99106 plug into those corner lights? I was under the impression you had to get Land Cruiser (early year) corners to run the turn signal bulbs.
Correct. The only noticeable difference between the 98-05 and 06-07 is the 06-07 corner lights will have the bluish tint to them. All the connectors I have are from the Landcruiser so that they will work with the LX. You just have to splice the wire into the factory turn signal wire so that the corner light will work with the turn signal.
