- Thread starter
- #401
Tues or Weds., depending on how fast paint & primer will dry.
Hey Jim, my 77 2F has Saginaw PS and the factory smog pump, will this idler pulley work OK when i remove the smog pump?Edit 9/22/14: All desmog parts are in stock & ready to ship.
Some desmog parts are in stock and ready for shipment. Note that actually removing federally mandated smog equipment from a street legal vehicle is against the law. These components will allow the use of later model engine and steering parts in earlier Land Cruisers.
First is the v.3.3 AIR pump idler pulley for 81-87 2F. The bracket is made of computer cut 1/4" plate and DOM tubing. The bracket is welded together but is designed so the welds are all redundant, bolts are also holding it together when assembled. The pulley wheel is made in USA and fits wide (Cruiser) belts. Assembly drops into stock lower pivot bracket, uses stock upper tension bracket and keeps stock belt size for easy replacements. Pulley wheel is a standard industrial part that can be easily replaced from a motion supply house or lawnmower store.
The tension drawbolt will still work with the lockbolt, but I don't recommend actually using the drawbolt to tension the pulley. The drawbolt is there to assist in moving the awkward air pump and fighting the stiff air hoses. Reasonable belt tension (it doesn't need much) can be achieved by simply yanking out on the pulley by hand, then tightening the lockbolt & pivot. Once a moderately snug belt is set, then the draw bolt can be slipped onto the lockbolt and tightened up, to insure the idler doesn't move in.
This piece is necessary on a Cruiser using a stock 81-87 PS pump. The PS pump picks the alternator belt up off the fan, leaving only the air pump to tension the fan belt. If the vehicle doesn't have an air pump, then this idler can be used to restore the needed fan belt tension function.
Price is $110, plus $5 PriorityMail shipping. PayPal can be sent to fj40jim a t gmail do t com.
If purchasing more than one component (see post below for others), shipping is still $5 for the total order. All 3 will just fit in a small flat rate box.
Thanks Jim, got these yesterday. In your experience, should the plugs be seated with loc-tite or similar?Thanks Chet! I was OOT Fri-Mon. Your goodies will be in the mail today.
